Machine Vision
Network disconnects when using GigE camera
Hi all,
I have a GigE camera using the NI high performance driver (intel pro 1000) - works fine on its own.
I have aerotech motion system (Ensemble) using a different network connection - works fime on its own.
But when I use both together after some number of hours of no issues the aerotech communication fails.
Have tried changing the IP addresses.
Aerotech
Card                 192.168.7.1
Ensemble          192.168.7.100
NI Camera
Card                 169.254.58.135
Camera             169.254.184.197
subnet mask     255.255.0.0
Has anyone else had a similar issue and resolved it by any chance?
Any ideas for me would be appreciated.
Certified LabVIEW Architect
(3,577 Views)
Hello Martin,
Thank you for your post, I have been looking to see if anyone has had similar problems with connection loss. After looking through public resources and not finding the information I was looking for I looked into previous support queries and it seems we have had a customer with a similar issue and this was partly due to firewire bandwidth.
When configuring your system and setting up the external wiring you should have the option to input the signal through the firewire bus on the motherboard or going through a PCI/PCIe to the motherboard. It is recommended to do the latter because if the firewire bus is shared communication could drop especially if you were attempting an image acquisition. The concern is the bandwidth on the firewire bus may be too great with the camera and motion card together.
I hope this helps you with your troubleshooting, please get in touch if you have any queries.
Regards
Stephanie L
National Instruments UK and Ireland
(3,547 Views)
