Machine Vision
NI web cam driver on target machine - problem
NI IMAQ webcam driver is easy to install and use in development mode. How do I install it on the target machine (there's only Labview exe, Labview run-time and Vision run-time on target machine)?
(NI IMAQ webcam driver checks for IMAQ Vision and/or Vision Assistant on the machine during installation. I came up with work-around that helped to get software up and running (able to read to memory all VIs) - copy ImaqDirectShowDll.dll to target PC's System32 folder, but this won't enable proper webcam usage (error pops up))
Thanks!
(3,299 Views)
Hi vlade
You will have to copy Imaqdirectshowexport.dll, too.
Alipio
"Qod natura non dat, Salmantica non praestat"
(3,294 Views)
it worked after copying and registering imaqdirectshowexport.dll
I hope NI will upgrade this driver and make it easier to use in deployment.
(3,278 Views)
