Machine Vision
NI Vision application builder
Hi all,
I have developed a simple vi:
  • Vision Acquisition Express acquires images from a USB3 camera.
  • Vision Assistant Express process the acquired image to find some edges.
  • That's all.
Now, I would like to distribute this application to another computer. I'm working with Labview 2014 SP1, I have Application Builder module, as well as VDM 2014SP1, VAS 08/2014 and NI-Vision Run-Time 2014 SP1. I am able to generate the application and the installer. But when I install the application on another machine, it says that I don't have Vision Acquisition Software license (use trial). What's more, I use trial version, at least to see if the application works, but I'm not able to see the USB3 camera. I thought that I could generate my own vision application if I have the Vision Run-Time.
Anybody knows what's going on?
Thanks in advance!
David
(3,061 Views)
Hi drodrig,
every application developed using VDM requires a Run Time License in the target PC:
https://www.ni.com/en/support/documentation/supplemental/18/licensing-national-instruments-vision-so...
You'll need to purchase the following Run Time license and activate it in the target PC:
https://www.ni.com/en-us/shop/product/vision-development-module.html
(3,014 Views)
