Machine Vision
NI VISION error code 0x80040217
NI VAS 2017,NI VDM2017,NI VBAI 2015 and NI MAX were installed on my computer,
I tried to use the camera on my computer.but when I do tests through Max explorer I get this error message
My computer is 64-bitUpdate the camera driver to the latest version.
  • The acquisition of images in NI VAS also encountered one problem
屏幕截图 2020-10-30 161117.pngI have searched relevant posts in the forum, but I still don't know how to solve this problem.Do I need to update the NI VAS to the latest version?Or is there any other solution
look forward to reply
ding
(3,530 Views)
Accepted by topic author 丁一
A couple of suggestions:
1. Can you change the video mode? My integrated cam works with 1280x720 MJPG 30.00fps.
2. Have you reviewed previous posts on this topic? This one in particular may be helpful: https://forums.ni.com/t5/Machine-Vision/Error-0x80040217-The-error-code-passed-into-imgShowError-is/...
(3,495 Views)
Thank you very much for your reply.The advice you gave was extremely useful.My Integrated CAM worked when I changed the camera mode to 1280x720 MJPG 30.00 FPS
I saw the topic you mentioned before and didn't understand what it said, but now I seem to understand a little bit.
Thanks again.
(3,462 Views)
