12-30-2006 01:46 AM
01-05-2007 06:07 PM
Chris,
After looking at DVC's specifications for the 1412, it appears that it does have a CameraLink output, which means you should be able to use it with the PCI-1426. However, you may want to verify that you do have a CameraLink output on the camera.
There currently is no camera file listed for the DVC-1412 for use with NI's PCI-1426 card. So, you have two options:
1. Create a camera file by downloading the camera file generator: ftp://ftp.ni.com/support/imaq/pc/ni-imaq/cfgenerator/2.0.2/
2. Request NI to make a camera file for you (Option 4, after the jump): http://sine.ni.com/apps/utf8/nipc.specs?action=search&asid=1102
Jasper S
01-06-2007 01:53 AM
Jasper,
Thanks for the reply. There seems to be an icd file for the parallel digital version of the DVC-1412 camera for 1422,1424 cards available here : http://sine.ni.com/apps/utf8/nipc.product?pid=3542
Since DVC claims the command set between the Camera link and parallel digital camera is the same, does that mean I can use the same ICD file ?
Thanks again,
Chris
01-08-2007 01:32 PM
