Machine Vision
Modify VBAI parameters after export to VI
Good evening,
I exported a VBAI to LabVIEW 8.2 using the canned export utility.  I would like to modify the parameters slightly by forcing a user to input the template path for a Detect Defects (Golden Template) inspection.  I can break the bundle out, add the file path code, then rebundle it, but the "template path" will still show up in the parameters, which is not something I can have.
Would someone be willing to explain how I can break this control apart (if at all?)
Thanks in advance,
VisionGumby
(3,225 Views)
Hi Vision Gumby,
You should be able to right click on the parameters change the parameters to a constant.  Or you can also use an unbundle by name function to see all of the components of the cluster.
I hope this helps.
GG
(3,207 Views)
