01-13-2008
04:46 AM
- last edited on
07-01-2024
02:07 PM
by
Content Cleaner
Hello!
I will use labview software 8.2 (National Instrument) to control this CCD (MEADE DSI Deep Sky Imager PRO II monochrome CCD Camera ) through USB 2.0. I want to use this CCD to
do image processing. But, this CCD do not support direct show. So, I can not use this http://sine.ni.com/devzone/cda/epd/p/id/5030 .
This is MEADE DSI Deep Sky Imager PRO II monochrome CCD Camera link http://www.meade.com/dsi_ii/specifications.html. The detail of CCD is in this link.
I want to write a program to do image processing but have no library. Can you provide me with the library (xx.dll) of CCD driver?
Or
Can someone try this CCD to use labview ?
By the way oem28 is this CCD information file.
Thank you and best regards,
01-13-2008 01:59 PM
It looks like there is proprietary software available for the camera that handles the image acquisition. I suspect you could integrate the API for this into LabVIEW, either directly using call library nodes or by writing a C wrapper dll. This is probably the only way you will the images into LabVIEW, other than taking the images with a different program and importing them into LabVIEW.
Bruce
01-13-2008 07:57 PM
Hello!
I need to automatically control with this CCD and have to use this CCD to do image processing.
