Machine Vision
MEADE DSI Deep Sky Imager PRO II monochrome CCD Camera do not support direct show ( I need help )
Hello!
  I will use labview software 8.2 (National Instrument) to control this CCD (MEADE DSI Deep Sky Imager PRO II monochrome CCD Camera ) through USB 2.0. I want to use this CCD to
  do image processing. But, this CCD do not support  direct show. So, I can not use this http://sine.ni.com/devzone/cda/epd/p/id/5030  .
  This is MEADE DSI Deep Sky Imager PRO II monochrome CCD Camera link http://www.meade.com/dsi_ii/specifications.html. The detail of CCD is in this link.
  I want to write a program to do image processing but have no library. Can you provide me with the library (xx.dll) of CCD driver?
  Or
  Can someone try this CCD to use labview ?
  By the way oem28 is this CCD information file.
  Thank you and best regards,
(5,058 Views)
It looks like there is proprietary software available for the camera that handles the image acquisition.  I suspect you could integrate the API for this into LabVIEW, either directly using call library nodes or by writing a C wrapper dll.  This is probably the only way you will the images into LabVIEW, other than taking the images with a different program and importing them into LabVIEW.
Bruce
Bruce Ammons
Ammons Engineering
(5,045 Views)
Hello!
  need to automatically control with this CCD and have to use this CCD to do image processing.
(5,039 Views)
