Machine Vision
Line fit with caliper
Hi, I'm a newb and I've got a little problem.
I'm processing an image with NI Vision assistant and I'm trying to make a line fit using caliper function.
How does this function works? I mean: the result is an angle and the deviation form the correct fit, but how has the angle been measured?
Thanks a lot
Sofia
(3,118 Views)
Hi Sofia,
Please refer to the following post linked below:
Image Position Analisys
It provides a brief but clear description on how the function Caliper works. Tell me if it contains the informations you need and if you need additional support.
Please let me know!
Cheers
Matteo
(3,081 Views)
