Machine Vision
LabVIEW and Halcon
Sorry for the late reply, i figured it out by myself in the end. I found out that the pointers were the problem.
What I do now is during the initialisation I create a HWindowControl (HSmartWindowControl is NOT working properly, in my case at least), define all the settings (Handle, implementation in HDevEngine,...) and then I send the WindowID as an input of the procedure I call (which I created myself for other data manipulation and contains "visualize_object_model_3d" at some point). As a result I get the display window directly in the front panel of my VI.
No doubt your solution works as well but this is way is a bit different so I thought I would share it if that can help someone. I have been struggling with this for a long time.
Thanks for your time anyway.
Message 51 of 70
(7,411 Views)
HI dadreamer,
Using the vi: LV_Image_To_Halcon_LV2014.vi ‏31 KB ,Ican conver a gray image to halcon image;
But,now the image is a RGB  format , I  don't kown hao to do. Can u help me?
Message 52 of 70
(7,345 Views)
This is for 3-channel RGB image.
Message 53 of 70
(7,336 Views)
Nice,just very  thankyou for you help!
Message 54 of 70
(7,329 Views)
Test under this program LV TO HALCON image running time is long will be out of memory and then an error please help below the answer thank you   LV2014    HALOCN12.0
Message 55 of 70
(7,100 Views)
You repeatedly allocate the memory with DSNewPClr and nowhere you free that memory with DSDisposePtr. That is the issue.
Message 56 of 70
(7,092 Views)
Where will the release function report an error
Message 57 of 70
(7,088 Views)
1631673723(1).pngThis change is good
Message 58 of 70
(7,086 Views)
You should dispose of the memory right after you have generated a HImage object with GenImage1 or GenImage3 method. This is from the sample that I posted earlier.
Please, don't use CIN method because it's unreliable in some cases.
Message 59 of 70
(7,075 Views)
It feels good to try. Does LV call Halcon have many bugs
Message 60 of 70
(7,071 Views)
