‎06-16-2015 02:12 AM
Hi
We use Vision Builder for machine vision. There are two interfaces in Vision Builder (Inspection Interface & Configuration interface). It is better machine vision operator would work with Inspection Interface and he should not access to all of setting and tools but he need to redefine some parameter like RIO in some tools like measuring tools for different products.
Is it possible to move some tools or their setting parameter from Configuration interface to Inspection Interface?
Or is it possible to define security like password to some tools and their setting but not all of them?
Refa
‎06-16-2015 05:10 PM
Vision Builder generally isn't supposed to rely on user input, but there is a step called "User Input" that allows you to get input from the user. ROI would be tricky. I think the slickest way to do that would be to create a VI that displays the image, lets the user drag a rectangle, then pass those coordinates back to Vision Builder to configure the ROI.
‎06-16-2015 05:13 PM
It looks like even that method would require a significant amout of customization.
