Machine Vision
Internal IMAQ Image representation: Left/Right Alignment
In the pdf-document "IMAQ Vision Concept Manual" there is a chapter called "Internal Representation of an IMAQ Vision Image" at page 1-6 (or 21).
This chapter says:
The size of the alignment blocks depend on the image width and border size. Aligning the image increases processing speed by as much as 30%.
Is there any function I can call to make sure that the image is aligned correctly, or is this taken care of automatically by IMAQ?
I am using IMAQ Vision 6.0.5 under Visual Studio .NET, C++.
Torbjørn
(3,319 Views)
All images created by IMAQ Vision are automatically byte aligned for optimum performance. The user does not need to take any action to make use of this optimization.
Kevin Crotty
IMAQ Vision Algorithms
(3,315 Views)
Thank you! -Then I don't have to worry about that.
Torbjørn
(3,290 Views)
