Machine Vision
Interfacing FPGA with Adsys Frame grabber
I'm using a frame grabber the Prolight 1101 from Adsys Control to pull off data from a line scan CCD camera through a camera link protocol in base configuration. The frame grabber is mounted on th PXIe 7975r FPGA. Is ther any ressources that can help me pulling the data using the camera link protocol!?
Thank you very much
(3,115 Views)
I would reach out to ADSYS Controls for this one. When you add the FlexRIO Adapter Module to your project, you will see items under the CLIP that will in some way map to the I/O of the module but ADSYS will be the best people to answer how you should be using this.
(3,081 Views)
Thanks I will contact them!
(3,072 Views)
