Machine Vision
Installed IMAQ Vision and get an IMAQ Boot Can't Find scarabXC2S20.bin error.
After installing IMAQ Vision 7.0, when my PC boots I get and IMAQ Boot Can't find scarabXC2S200.bin file error. I do not have an IMAQ card installed in my PC.
(3,016 Views)
Hello.
This is a file that is installed in the following directory: C:\Program Files\National Instruments\NI-IMAQ\bin
It sounds like you maybe are not using the NI-IMAQ driver. In that case, you should proceed with an uninstall of the driver through the Windows Add/Remove Programs.
In the event that you are using the IMAQ driver, it sounds like you simply have a bad installation. To fix this, proceed with an uninstallation as mentioned above, and re-install the driver. Linked her
e
is the driver download page for our latest IMAQ driver.
Hope this helps!
Colin C.
Applications Engineering
Colin Christofferson
Community Web Marketing
Blog
(3,016 Views)
Thank-you Installed NI-IMAQ 3.0 and the error has gone away.
(3,016 Views)
