Machine Vision
Instability in pattern matching
Can you post a few images?
Message 11 of 117
(3,998 Views)
I'm trying to get a fail so i can post the "good" and the "bad". Smiley Tongue
Message 12 of 117
(3,996 Views)
Also post the fiducials as the camera sees it.
Message 13 of 117
(3,995 Views)
Here it is. i'm sorry for the patch but i need to hide the client's name. Here you can see the fiducials and the areas of search with the relative components. This is a good image. After the modification that i explained before i had done 100 runs but i could not get a single "fail", instead i have obtained a pretty costant match score.
Message 14 of 117
(3,989 Views)
and what is your reference in this image?
Message 15 of 117
(3,975 Views)
Sorry i did'nt get it, do you mean the fiducials?
Message 16 of 117
(3,971 Views)
yes
Message 17 of 117
(3,967 Views)
The three  points that you can find in the upper left corner, in the lower left and in the upper right.
This one:
Message 18 of 117
(3,961 Views)
I honestly feel is the image is good. I feel if you are taking the fiduals reference corerctly the application should work correctly and ofcource with uniform lighting.
Message 19 of 117
(3,949 Views)
I already checked the fiducials and i can exclude that they are the problem. Honestly last week there had been some cloudy days with the sun that come and gone from time to time. So i think that the principal problem is my inexperience with the pattern matching function and the working mechanism behind the result, so i expect something that i couldn't really achieve due the terrible conditions that i experienced last week.
Today is a really sunny day and it seem that the code is working pretty well. I work really close to a window so i take all the changing in lighting. I know that this are terrible conditions to work with, when talking about image analysis, but i thought that if i can make a software that can work under this circumstances when i will put all the stuff inside a closed dome i will be sure that everything will work very well.
Message 20 of 117
(3,946 Views)
