Machine Vision
Instability in pattern matching
Please read the template once (not every iteration unless you need to learn on the fly). This is important to make use of cache. Once the template image used for matching cache is active in template image as extrainfo (will not be saved to disk). The same cache is used for next matching iteration. This helps lot in reducing computations.
What is the timings with your latest code?
Message 111 of 117
(1,554 Views)
Timings with my latest code:
(1) First run - Matching time: 1183 msec.
(2) Second run - Matching time: 784 msec.
(3) Third run - Matching time: 792 msec.
Message 112 of 117
(1,548 Views)
Hello Antony,
My lastest code and lastest template (as attachment).
I use template editor, too. Template editor automatically sets value "max pyramid level to store = 2". I have this value changed now and saved new template (PM_pyramid_template_lv4.png)
Message 113 of 117
(1,540 Views)
Hi desalando,
Timings looks good now. I hope it suffice your requirements. Please post again if you come across any issues.
Antony
Message 114 of 117
(1,525 Views)
hi  FM82
           i am new to labview image processing .i need to impliment your fiducial concept relocated my Pattern matching ROI. is it possible to get your code .
Message 115 of 117
(1,477 Views)
hi FM82,
            i need your this fidiucial concept code . to relocate my ROI of pattern matching
Message 116 of 117
(1,477 Views)
please can you share with me the vi ,i have the same project but i can't keep component overlayed
Message 117 of 117
(1,407 Views)
