Machine Vision
Image to Array and find hotpixel
dear forum,
 An image is loaded ( see attached testimg) and converted to an array. In this image (array), some pixels have a gray value greater than 1. These pixels are to be found and their position (x/y) should be stored in a text file (or csv...). Is there an example for this application or has someone  a snippet for me?
(3,016 Views)
Dear Hallmann,
as you already found the image to array function, you can just use the compare function to iterate through your 2D array. Together with the conditional output of a for loop you can write the corresponding addresses into a 1D array. For data logging, just have a look into the File I/O Palette.
cheers
Fabian Wehnekamp
Senior Technical Support Engineer
(2,966 Views)
Accepted by HallmannSVS
Dear Fabian,
 thank you for your replay. You right, you suggestion is an sulotion.I have also found a solution.see attachementSolution_hot pix.JPG
(2,939 Views)
