Machine Vision
Image process help - script & image attached!
U want a vi or a script file?
Message 11 of 17
(4,061 Views)
R u new to image processing or new to labVIEW itself? HAve basic idea of subVI and edged detection techniques?
Message 12 of 17
(4,060 Views)
Please try something from your end.Start coding i assure you that everything will fall in place.
Try labVIEW is easy and helpfulSmiley Wink
Message 13 of 17
(4,058 Views)
I've been coding in Labview for a few years now but I'm quite new to image processing.
Finding the centre defect was quite easy due to the contrast change but the outside edge failures are alot more difficult.
I find the image builder easier to use since I can quickly change source images and track each step individually.
Any help with the edge defect would be great. I'm now having any success with the laplacian filter Smiley Sad
Marke
Message 14 of 17
(4,033 Views)
Ok lemme try it for you.In the mean time explore threshold and particle analysis.
Message 15 of 17
(4,030 Views)
Find the script file created in 8.0.Hope it helps
Message 16 of 17
(4,027 Views)
Here is the vi i tried.
Message 17 of 17
(4,026 Views)
