Machine Vision
Image process help - script & image attached!
I've managed to pass fail the jet hole but cannot seem to find a suitable process for the edge failures.
Any advice or examples would be great!
Script and images attached.
Marek
Message Edited by marekm on 07-07-2008 04:30 PM
Message Edited by marekm on 07-07-2008 04:31 PM
Message Edited by marekm on 07-07-2008 04:33 PM
Message 1 of 17
(9,203 Views)
Find the vi for centre defect detection.Similarly set a proper threshold and use a particle analysis for edge defect detction
Hope it helps
Dont forget to rate a good answer
Message 2 of 17
(9,186 Views)
Labview cannot find IVA Binary Inverse, is this your own VI or part of the IMAQ toolkit?
Did you create this VI using the image assistant or did you do it the old fashion way?
Marek
Message 3 of 17
(9,175 Views)
I created this from vision assistant.U can call a direct vi from labVIEW. Hope it helps!!!!
Message 4 of 17
(9,162 Views)
have u done with your second part?I will not advice you to go with pattern matching.Apply a laplacian filter with highlight details then set a proper threshold.This i feel will increase your consistency
Message 5 of 17
(9,154 Views)
I am new to image processing. Do you have a script file example I could look at?
Many thanks
Marek
Message 6 of 17
(9,135 Views)
HAve u used the previuos vi i posted.Is it helpful. Let me know the result of your trial.
Message 7 of 17
(9,126 Views)
Find the attached script file
Message 8 of 17
(9,106 Views)
The script file has been created with vision assistant 8.
Message 9 of 17
(9,105 Views)
Thanks for your help guys, I can now reliably check for swarf in the centre jet.
However, I still have the major problem of checking for the inperfections around the outside edge of the jet. I tried using a laplacian filter to highlight the edges and create a threshold but I haven't had any reliable success (I have to admit I don't know to configure the filter correctly!).
Any ideas on this part?
Thanks again!
Marek
Message 10 of 17
(9,087 Views)
