Hi...can anyone tell me how to go about doing the following image calibration steps done?
I have an image that is grabbed using IMAQ PCI 1424 card using dalsa camera. My image consists of a plain black one with white intensity spots placed at equidistant on the image(something like the one u see in the calibration grid except that the spots here are white and the background is dark).I have to specify a uniform grid around each one of the spot so as to make a selection of the spot. Now for each grid I have to find the centroid and my final output should be an 2-d array which is the centroid of each of the grids. How can I go about getting this done? I use LabVIEW Ver. 6.0 and IMAQ vision 6.0.
I would suggest using the calibration routines. Invert your image and use it as the calibration grid, with grid spacing of 1. I can't remember if one of the outputs of the calibration is the points of the grid. If not, you could just loop through a range of world coordinates that covers all possible situations and look up the corresponding pixel values.
hi... Iam new to LabVIEW and still in the process of learning...I cant clearly understand your suggestion. I am attaching a sample image file on which the above said operation has to be performed.Can u suggest me clearly about it. And am looking at calculating the centroids of the individual grids.How do I do it? Thanxs... Veena.
Dear Ms Veena, I have seen your post and I would like to know the detials of your current activity.Please mail me at hmishra@iitk.ac.in I am also involved in Vision activity using a webcam.
