The IVA Match Geometric Pattern Algorithm.vi was generated by NI Vision Assistant. It is basically a wrapper for IMAQ Setup Match Geometric Pattern and IMAQ Setup Match Geometric Pattern. These functions (are included with the Vision Development Module, and can be found on the LabVIEW block digram under Functions»Vision and Motion»Machine Vision»Searching and Matching.
