Machine Vision
IMAQdx.ctl
Hi all
I'm trying to load a labview program that use vesion library
I made sure I have IMAQdx install with my version
still when running it is not workeable(broking arrow) becouse it can't find IMAQdx.dll
I serch for it in c or in labview folder and could'nt find it
aprricate your help
Israel
(10,752 Views)
Here: C:\Program Files (x86)\National Instruments\LabVIEW 2015\vi.lib\vision\driver\IMAQdx.llb
If installed correctly.
-Check in License manager whether Vision Development  and Acquisition Module is installed.
uday
(10,737 Views)
Hi, sorry for the mastake
I was looking for IMAQdx.ctl
thank you in advance
israel
(10,718 Views)
What version of LabVIEW installed?
What version of vision development module installed?
What version of vision acquisition installed?
What vi you are trying to open and get this error?
If possible post vi.
uday
(10,713 Views)
IMAQdx.ctl should be located in:
C:\Program Files (x86)\National Instruments\LabVIEW 2015\vi.lib\userdefined\High Color\IMAQdx.ctl
NIIMAQdx.dll should be located in:
C:\Windows\SysWOW64\niimaqdx.dll
C:\Windows\System32\niimaqdx.dll
(10,708 Views)
Accepted by Israel123
Hi Israel,
Please double check that the ctl is located at C:\Program Files (x86)\National Instruments\LabVIEW 20xx\vi.lib\userdefined\High Color. Is LabVIEW having trouble locating other IMAQdx VIs?
Please also answer the questions someone posted on the versions of LV and VAS you have.
Are you trying to open an example? Is this a VI you built from scratch? Please post more details on this as well.
AGJ
(10,689 Views)
Hi all
Thank you for all your answer
the problem was that I'm new to labview and didnt anderstand the way it installed
I thougth by having the vision at National instrument folder it mean rhat I can acsses it,
as it's thern out this folder is block in my version.
I disable the vision part in my Vi becouse it was not essntial to me
and mannage to work with the Vi
Thank you all again
israel
(10,681 Views)
