Machine Vision
IMAQdx Attributes
Based on the old grab and attributes example VI for the IMAQ legacy 1394 driver I wrote a VI that was able to change the attributes of the camera Basler 311f. Now I want to convert this VI to the new IMAQdx driver. Therefore I tried to use the new Grab_and_Attributes_Setup.vi. It works really fine but I have the Problem that I just don't understand it and can't implement the for me needet changes. It is nice that I can change every Attribute with it but I just want to change the Shutter Speed and Gain. Over that I don't want to change the Shutter Speed dynamically but only in fixed steps to given values.
I searched for more example VIs but was only able to find a thread on this board where someone said something about a set_camera-shutter.vi but I wasn't able to find it.
Best regards
AS
(3,867 Views)
Just use IMAQdx property nodes to configure the values for the shutter speed and the gain.
Bruce has pointed it out in detail here.
Hope this help, Guenter
(3,827 Views)
Thank you, that was the hint I needet.
(3,786 Views)
