Machine Vision
Showing results forĀ
Search instead forĀ
Did you mean:Ā
IMAQ init error
1.    Just use init--->snap--->close.Nothing else and tell us whether this is working.
2.   Open vision assistant.Try acquiring image with it.See if successful.
If iy is successful then u have done some mistake in the code. So it might require you to post the code here.
Message 11 of 17
(1,738 Views)
Yes, it works, like I said - in other parts of my code, everything works fine - I've used MAX and examples and my other code and it works fine - I just can't see why this particular piece of code does not - it is wired exactly the same
Message 12 of 17
(1,736 Views)
Attach the code for us to look at it.
Message 13 of 17
(1,734 Views)
Then the only way is "Did you hear Brucemoyer?"
Message 14 of 17
(1,728 Views)
Rewrote the case state with the same code and it worked
Message 15 of 17
(1,715 Views)
Really glad that it works. But i dont understand what u mean by rewrote the case.Did you do any modification?Where you having some  init in the default case?
Message 16 of 17
(1,697 Views)
My guess was that something was miswired, it doesn't even seem like this guy knows what was different, but something was.
Case closed.
Message 17 of 17
(1,692 Views)
