‎07-10-2008 09:59 AM
‎07-11-2008 05:00 PM
Hi Chris,
Check out this forum post regarding error 1074396024 with the USB camera driver. I hope this helps 🙂
‎07-14-2008 08:43 AM
‎01-13-2010 03:28 AM
Hello:
I have just been given a Declink Studio F/G and would like to use LV instead since I am used to it a lot while doing microscopy work before. I've read your post mentioning about drivers you can obtain or used in the past for Decklink also. I would appreciate your help in how to obtain then and some starting code if you permit for me start working on my project. I hope for your kind consideration and thanks for your time.
Berns B.
‎01-13-2010
08:27 AM
- last edited on
‎03-26-2025
11:06 AM
by
Content Cleaner
Dr. Berns,
The Decklink boards come with Directshow drivers, which tie the video source into windows through the DirectX architecture. The beauty of this method is that any software can access the video stream easily without special drivers. If you have LabVIEW2009 with the Vision Development Module:
or the Image Acquistion Software:
https://www.ni.com/en-us/shop/product/vision-acquisition-software.html
You'll see the Decklink board in Measurement and Automation Explorer.
If you have LabVIEW 8.6, the NI-IMAQ USB provides similar functionality:
The API for both of the above methods is very similar to the standard IMAQ API. Hope this helps.
‎01-13-2010 06:42 PM
Hello Chris:
Kudos to you ! Overnight you provided me with very good insight on how to work around this F/G (which I only got late afternoon yesterday) I follow your indications.
Thanks very much.
Berns B.
