Machine Vision
IMAQ Segmentation VI
when using  IMAQ Segmentation VI,there is an error saying invalid image type.
and program is in the following:
7BB[WB7K3[YSZ@LH0@O{875.jpgwhat's the matter?i really appriciate your help.
Message 1 of 10
(5,871 Views)
Dont you think the wiring can be better? Instead of attaching a part of your vi can you attach your vi instead or the entire screen shot after cleaning? What is the image type that you are trying to segment? Have you thresholded the image? Have you defined individual buffers(IMAQ create) for the each of the transformation/conversion (RGB,GReyscale,Binary)?
Message 2 of 10
(5,863 Views)
sorry,this is a starting project,i'll deal with the wiring later.the shot screen has a problem,the image type of image7 is graysclale,but even that the same error is existing.i have threshholded the image and i have defined the buffers.
Message 3 of 10
(5,855 Views)
In the "image 7" you have defined the image type as a RGB change it to grescale 8. The error should go off.
Message 4 of 10
(5,853 Views)
i changed both the segmetion VI and the label VI's image type to GRAYSCALE U8,then the program went right but  the result is not what i want.i will check it .tk u very much muks.
Message 5 of 10
(5,851 Views)
You should apply a proper threshold? I willsuggest you first try the segmentation with vision assistant to get an idea.Generate a vi from vi assistant.
Message 6 of 10
(5,849 Views)
thk you,i will try.
Message 7 of 10
(5,834 Views)
Accepted by topic author tuming
Solved?
Message 8 of 10
(5,769 Views)
Any update?
Message 9 of 10
(5,711 Views)
sorry.too late to reply.it was solved,thank you.
Message 10 of 10
(5,697 Views)
