Machine Vision
IMAQ Quantify - calculations results
I have question regarding IMAQ Quantify function from Vision and Motion toolkit. I hope the attached example vi explain what I mean.I would like to receive calculation results related to labeled image mask areas, not related to whole image area.Is any efficient way to get functionality I need?
IMAQ Quantify vi use LV_Quantify function. What LV_Quantify_Bounded function does?
Many thanks in advance.
Sorry for bad english 😉
(4,528 Views)
Accepted by arturs
Hi
If you can make sure your thresholded image is binary (only 0's and 1's), you can easily use the "Mean value" value to know the number of thresholded pixels in each region. Have a look at the example I've modified.
Vladimir
View my profile on LinkedIn
(4,491 Views)
Many Thanks. This is the best solution.
Kind regards
Artur
(4,475 Views)
Can someone make this example into LV8.2?
Branson
(4,094 Views)
Here it is
(4,090 Views)
Which vi? the modified? the original? You can directly quantify your image if you have vision assistant. Try it..:smileywink:
(4,089 Views)
Thanks!
(4,084 Views)
