08-13-2017 12:09 AM
What is the best method(IMAQ Extract Curves / IMAQ Extract Contour) to use to extract a closed contour/curve for the above image?
The right image is drawn by hand to illustrate what I want.
What is the application difference for these two methods?
08-14-2017 12:25 AM
before to do you need to improve your image adage by some function like filters and contrast after that I think the magic Wang is good method for your aim
08-14-2017 12:29 AM
also contour search for just close curves
you can use imaq curve for find close curve by setting but I think imaq contour is better for this one
08-19-2017 11:16 PM
Thanks, Magic wand is also not a bad idea although it cannot do subpixel accuracy.
05-18-2018 09:14 PM
IMAQ Extract Curves 是找所有的曲线,并输出出来。IMAQ Extract Contour一次只能输出一条线,并且有方向等设置,场景不一样,用法不一样
