Machine Vision
IMAQ Error - Serial Port Error on Camera Serial Command
I am trying to use camera serial commands that embedded in icd file. I got the following error:
Error0xBFF6003B
Serial Port Error.
Command Sent: !=3\r
Expected Response: G=3\rA=52437056\rB=52169323\rH=52169323\r\S=-1\r.....\xce\xe8\...x01\r>Ok\r
Actual Responose:  G=100\rA=0\rB=0\rH=3\rS=0\rT=0\rI=105\rM=1\rO=0\rP=0\rQ=0\rR=0\rPLICamera CCD\r>Ok\r
Below is from my .icd file thatcause the trouble:
    Attribute (Camera Config) {
      Value (Integer) {
         Min (0)
         Max (8)
         Increment (1)
         Display {
            Offset (0.000000)
            Multiplier (1.000000)
            Precision (0)
            Units ([0;8])
         Default (3)
         Current (3)
         Action (Serial) {
            Command (!=%d\r)
            Response (G=%d\rA=%d\rB=%d\rH=%d\rS=%d\rT=%d\rI=%d\rM=%d\rO=%d\rP=%d\rQ=%d\rR=%d\r%s\r>Ok\r)
 Do you have any idea why I getting the garbage in Expected Response line?
Polarfox
(4,041 Views)
Hi polarfox,
What camera and framegrabber are you using?
Jeff | LabVIEW Software Engineer
(4,021 Views)
I use Aviiva SM2 CL linescan camera.
(3,986 Views)
Which cameralink board are you using? And which specific model of that camera are you using? I don't see one without a number in the SM2 CL line here.
(3,965 Views)
