Machine Vision
Applying multiple Geometric Pattern Match Modes in C#
I have a pattern match function that works well in the Vision Assistant for my images. I create a builder file or C file and it says I need to set the CWIMAQMatchGeometricPatternOptions.MatchMode to 7, which I take to mean as multiple match modes (There are 4. I'm assuming they are assigned values 1,2,4, and 8 and that they add together. 7=1+2+4).
In the Example program, it shows MatchModes being added together:
MatchMode =  CWIMAQGeometricMatchModes.cwimaqGeometricMatchOcclusionInvariant;
MatchMode = MatchOptions.MatchMode + CWIMAQGeometricMatchModes.cwimaqGeometricMatchRotationInvariant;
But this will not compile.
How do I add multiple modes?
(3,781 Views)
Accepted by topic author dstanisl
Found it:
You need to cast the number as a CWIMAQGeometricMatchModes
MatchOptions.MatchMode = (CWIMAQGeometricMatchModes) 7;
(3,780 Views)
