10-02-2006 01:11 PM
10-03-2006 03:57 PM
10-04-2006 06:24 AM
Chris,
I have Vision Acquisition Software only and I can write compressed files. Yes. Today the codecs work. My camera's max image size is 659x493. One of the new codecs out of the Cole2K package put up a warning dialog stating that the implementation might need image sizes in multiples of 32 wide x 16 high. So, I tried setting the ROI to 640x480 and, presto, most of the codecs worked. After some experimentation I discovered that the troublesome codecs have an upper limit to image size of 640x480. Anything under that worked. Anything over that generated the error.
