Kevin,
The 1024x768 YUV(4:2:2) mode is not necessarily only for testing.
It is simply a standard mode that has been provided by the camera
manufacturer. Format 7, Mode 0 is generally used in the case when
you only want to acquire a portion of the image or use a non standard
acquisition rate. This may not be necessary for your
application. If the first mode is working for you then I would
recommend using it.
As for why the Wait on Occurance VI is timing out I think it would have
to do with the settings of the packet size or the timeout. It is
possible that the camera is taking longer than the timeout for the Wait
on Occurance before it completes the snap. Here is a document
that has some useful information on setting up Format 7.
http://zone.ni.com/devzone/conceptd.nsf/webmain/A533E1E5A109CBCE86256D8E00768814?opendocument&node=201714_US#5
S. Arves S.
