12-13-2004 01:36 PM
12-13-2004 10:20 PM
12-14-2004 11:02 AM
12-14-2004 11:33 AM
04-11-2007 09:30 AM
04-12-2007 01:22 PM
Hello Maxime,
Acquiring from multiple firewire cameras concurrently is supported in the IMAQ for 1394 driver. The only limitation you will face is with the data-width of the FireWire bus. The DevZone document linked here describes this issue and offers many considerations. As for an example of this functionality, as the previous posters noted, there are no shipping examples that come with the driver that perform this operation. However, you should take a look at another forum post, linked here, in which a user has attached a VI to do this.
Jasper S
04-13-2007 06:27 AM
05-02-2007 12:00 PM
I am also interessted in this. I cant cet both cams working using the same firewire card. 2 cards 2 cameras or only 1 session at a time. What is the fix. I dont have enough PCI slots for multiple cards.
Paul
05-03-2007 02:44 PM
Paul,
There is no reason why you should not be able to acquire from both of these cameras simultaneously. I would suggest ensuring that you can acquire from both cameras separately, and that they have distinct identifiers in MAX (cam0, cam1). You should also set the rate for each camera to 200, which half of the bus width, which will allow both cameras to acquire at the same time.
Jasper S
05-07-2007 07:16 AM
I am currently acquiring both cameras seperatly with no problem, it is more of a firewire card issue, the bandwidth seems not to set on the card, I set coth cameras to 100MB and each work independently but never both together.
Paul
