Machine Vision
IEEE 1394 Camera Trigger Mode 1 Problem
Hello!
I'm using IMAQ with VB and IEEE1394 camera. My problem is folowing.
When I start Trigger Mode 1 and start grabing picture, I yust cant stop triger mode,
because all buttons are inactive. I must push Stop Acquisition and then one or more times activate
trigger. Is there any other solution to normaly get out of Trigger mode and yust stop it.
Can anyone provide any solution?
Regards!
Message 1 of 32
(7,407 Views)
You cannot change the acquisition mode of the camera during a grab. You must stop the acquistion and then change the mode. I'm sorry but there is no way to change the trigger mode during the grab.
Christopher W.
Message 2 of 32
(7,371 Views)
Hello!
I don't want to change the mode. I'd yust like to stop waiting for trigger signal. After I have started Acquisition in trigger mode 1 all controls on form are inactive. So I have to press
control button to stop acquisition and then insert trig signal once more.
Can I yust go out of this mode without inserting trigger signal?
Regards!
Message 3 of 32
(7,371 Views)
Hello!
I just need some function that will make event when trigger is activated and picture is acquierd in Visual Basic, like function in NI library
imaq1394ConfigEventMessage. I just need solution that my controls on form are not deactivated.
Please any info?
Regards!
Message 4 of 32
(7,356 Views)
Look at the Trigger1394 example.  This does a triggered snap.  It will snap once and then it will be done and won't be waiting for the trigger signal again. It is located at C:\Program Files\National Instruments\NI-IMAQ for IEEE-1394\Examples\VB
Christopher W.
Message 5 of 32
(7,339 Views)
Hello Chriss!
I've seen that. But what if user doesn't want to wait for this trigger event, maybe he changed his intention and he like to stop acquisition and that why he should stop this acquisition in trigger mode without waitiong of trigger event. What then? In this case he have to fire one trigger event.
Any idea?
Regards!
Message Edited by danilo on 10-25-2006 04:05 PM
Message 6 of 32
(7,334 Views)
So you want to set it up for a trigger and then while its waiting for a trigger allow the user to change his mind and say that he does not want to wait for a trigger? This is not possible, once it is set up to wait for the trigger you do need to stop the acquisition to change the mode.
Christopher W.
Message 7 of 32
(7,312 Views)
Hello Chriss!
I can understand that. But what should I  do to avoid waiting for new triger pulse, to exit from triger mode acquisition?
Regards!
Message 8 of 32
(7,299 Views)
You can't avoid waiting for the trigger once you have set up the acquisition.
-Christopher W.
Message 9 of 32
(7,285 Views)
I stumbled on the same problem in my application. It is imperative for us to be able to cancel the trigger mode at any time. I downloaded the trial version of ActiveDcam software, and it lets me do it with no problem.  You just set the trigger property to false, and the acquisition continues in a regular mode. I don't seem to have such an ability in IMAQ.
Message 10 of 32
(7,027 Views)
