Machine Vision
IDS Camera triggering and saving images
I'm using a IDS ueye USB3 Vision camera which is triggered by an external hardware. I'd like to acquire and save an image every time the camera is triggered. So far I tried to use the attached vi from IDS and modified it to save the images. The triggering part works fine, but the images are saved continuously, regardless of weather there was a trigger signal or not. It's just saving images all the time. The ueye.Net.zip contains the original data from IDS and the uEye_Flash_and_Trigger_rev_buffer_time.vi is the file I modified.
I would be glad if anyone can have a look on this!
Thanks!
btw: I am using LabVIEW 2018 and Vision acquisition 18.0
(4,449 Views)
Hi
Any possibility you can downgrade the labview code to 2016 and attach it once again?
(4,419 Views)
