Machine Vision
I am having difficulty migrating vision builder scripts to Labview
I am using vision builder 2.0 and labview 7 and whenever I try to migrate the script to labview code, I get a whole lot of junk that doesn't do anything. If I use vision assistant 7, and migrate the script it works fine, but vision assistant doesn't have all of the functionality that I need from vision builder
(3,137 Views)
Can you please be more specific about what "junk that doesn't do anything" means? Does the Vision Builder AI 2.0 generated code simply not run or does it generate errors? Do you see the same problem if you open one of the Vision Builder AI example inspections and generate LabVIEW 7 code from the example?
Dawna P.
Applications Engineer
(3,137 Views)
I have seen errors when using an old version of vision builder with LV 7.
What features is vision assistant missing that vision builder had? I haven't studied it closely, but I thought they both had essentially the same functions.
Bruce
Bruce Ammons
Ammons Engineering
(3,137 Views)
