Machine Vision
取消
顯示結果
搜尋替代
您的意思是:
How to reduce an image from 1600 * 800 to 200 * 200 ? and to zoom it?
已解決!
前往解決方案
I am working on a projet and i need to reduce and to zoom the picture. so i can place points in it,
can you help me creating a block that will permit to reduce the photo by sketching it to 200*200
in second step i should Zoom and DeZoom it.. and also i dont know how to do it,
Thank you for you help,
Best Regards,
_________________________________________________________________________________________________
Salim Darwiche
Software Designer
Galteck -Switzerland
~~~~~~~~~~~~~~~~~~Looking for a LABVIEW JOB (In EUROPE)>~~~~~~~~~~~~~~~~~~
**The Best Way To Predict**The**Future Is To Invent It**
Salimos - View my most interesting photos on Flickriver
0 積分
1 條訊息(共 4 條)
4,025 檢視
解決方案
由主題作者所接受 salimo
To zoom and dezoom you should use the Zomm Factor property node . To use this property node I invite you to follow those discussions : bitmap image zoom in or out & zoom image where good examples are attached. Also you have a KB about resizing picture in LV and in the example finder of LV you have the Picture Control - Zoom Attribute.vi that I attached in 8.6.
Hopefully this helps.
Message Edité par Steve Mohamed le 02-04-2009 11:10 AM
Steve M.
2 條訊息(共 4 條)
4,004 檢視
To reduce the resolution of an image, you can use Extract Image to only keep every N lines of the images.  You can use different factors for the X and Y directions.
Another option is to use Resample.  This will resample the image to the specified resolution.  This is a slower method, but works well if you don't have integer scaling factors.
Bruce
Bruce Ammons
Ammons Engineering
0 積分
3 條訊息(共 4 條)
3,996 檢視
Just a little question concerninng the zoom, (witth the Scale Factor), is there any option that let me see the real pixels when i do the zoom, i dont want the picture to be soft, so when i zoom to the max i should see the real Pixel Square,
THank you again,
0 積分
4 條訊息(共 4 條)
3,973 檢視
