Machine Vision
How to identify a GigE camera by IP address
*Edit to the above post*
I mistyped and it is IMAQdx 4.1 that will contain the "open by IP address" session syntax.
Eric
Message 11 of 15
(2,052 Views)
Thank you , Eric.  That will work perfectly.
Message 12 of 15
(2,043 Views)
Eric
Hi Eric,
I have IMAQdx 4.2 installed, and can't see how to do this. Did this feature make it in?
Chris
Chris Vann
Certified LabVIEW Architect
Message 13 of 15
(1,951 Views)
Yes, just pass the "ip:<camera_ip_address>" syntax described earlier in this thread to the session name.
Message 14 of 15
(1,941 Views)
Hey guys,
about this Topic, because i have the same Situation - i wanted to make the camera session Independent from any MAX identifier.
Just wanted to add the following, because i was stumbling at a specific Point (once again):
Example-String: IP or MAC-Address
ip:192.168.0.1
uuid:001122334455
Very important, maybe applicable in general:
When you open a camera Connection independently from MAX you need to set the
AcquisitionAttributes::PacketSize
to the maximum value your Network Environment is providing, or any desired within this Limits, unless your Environment is supporting Jumbo Frames.
If you dont do this, you will be able to connect, but your code will freeze when you try to snap or configure grab.
Just wanted to Point this out, because i always fall for this 😉
cheers
Message 15 of 15
(1,361 Views)
