annuler
Affichage des résultats de
Rechercher plutôt
Vouliez-vous dire :
How to differentiate between flux, dust & impression...?
Hello... 🙂
     I'm using Vision Builder 3.5 & Camera with 3M pixel..... My problem is I have to check two carbon tracks on PCB for OK codition... there are three solder joints near the carbon tracks so I have to check that there is no flux on the tracks... But I'm not able to differentiate between flux, dust & impression... Is there any way to differentiate between flux, dust & impression...?
   Thanks for any help from you.. 🙂
0 Compliments
Message 1 sur 14
4 778 Visites
Can you post some sample images? The color of the flux may be unique, dust and impressions may show up with darkfield lighting.
Without seeing your scenario, it's hard to tell.
-AK2DM
0 Compliments
Message 2 sur 14
4 771 Visites
   Hello Rupali... Smiley clignant de l'œil
       It would be veru helfull if you could post some sample images,   The camera resolution is very good,  is the camera  color or monochrome
       also what lens are you using? you may play with the lighting
       Just thinking with out seeing the images,  you can use a zoom lens so you can zoom the image and get more definition...
        Best Regards...   Smiley heureux
Ing. Reynaldo Lima Villarreal
Ingenieria Electronica (I N G E L)
Reynosa, Tamps. México
Cel: +52 899 160-52-59
Email: reynaldolima@aol.com
0 Compliments
Message 3 sur 14
4 768 Visites
Hello.. 🙂
    Thanks for reply... 🙂 The camera is color & i'm using adjustable lens for zoom in & out... using ring light white color... here are some pictures... 🙂
Tout télécharger
0 Compliments
Message 4 sur 14
4 751 Visites
Here is another with flux image..
0 Compliments
Message 5 sur 14
4 751 Visites
I'll send you some more picture from the actual camera I'm using on production line... With the changes I have made through software... Right I'm playing with intensity part.. It detects the dust & flux very accurately.. But gives problem with wiper impression which are made during PCB testing... & those are present on 100% PCB... On some PCB's they are very dark... In that case my software gives false calls... n I want to avoid this... Can you help please...?
0 Compliments
Message 6 sur 14
4 750 Visites
                 Hi Rupali....
                 I take a look to the image you post,
                 The two carbon path are in very good shape to inspect using geometric match.  then you can try intensity on you inspection
                 any way can you post some pictures taken with the camera  that you have in the production line.
                 Best Regards..Smiley clignant de l'œil
0 Compliments
Message 7 sur 14
4 711 Visites
Hello Rlima...
     I have taken the pictures but they are in .bmp type n don't have converter to convert bmp to jpg.. I tried some free downloads but they does not working properly... And adding bmp files will occupy lot of space... 😞 what should I do now...?
0 Compliments
Message 8 sur 14
4 706 Visites
Hey got the solution... 🙂
Tout télécharger
0 Compliments
Message 9 sur 14
4 703 Visites
Here is another...
Tout télécharger
0 Compliments
Message 10 sur 14
4 702 Visites
