Machine Vision
How to communicate Vision Builder with Arduino?
I need to send the result of Vision Builder's inspection (Pass or Fail) to Arduino, but I have not found any documentation to establish a communication between Vision Builder and an external device. Does someone know how to make it? I have thought to use a serial communication but other types of connection are good if you know how to make them. Thank you very much.
(3,324 Views)
Accepted by Lancill8
Hi Lancill8,
I'm not sure of what you mean. Do you want to deploy Vision Builder on Arduino? Or are you running VB on Windows and want to communicate from LabVIEW to Arduino? There is no way to deploy VB on Arduino, but you can communicate from your PC with Arduino at a low level (using VISA and the serial port) or with a few toolkits that you can find on the VI Package Manager.
Best,
CorraDIT
(3,262 Views)
