02-23-2006 06:03 PM
I did a "back of the envelope" calculation for 3 framegrabbers each grabbing 8-bit grayscale NTSC video (640x480 res.) at 30 fps that went like this: 307 KB per frame * 30 frames per sec * 3 boards = 27 MB/sec. To me this seems pretty close to the PCI bus speed of 33 MHz. But I am not a computer engineer so I am not sure (I am not even 100% confident I have the bus speed correct).
Anyway, maybe there are other customers or applications in which multiple framegrabbers were run at the same time? I mentioned 8-bit images above and that is fine, but I would really prefer RGB color. Also, my target card count is three.
02-24-2006 02:35 AM
