09-01-2008 03:17 AM
09-02-2008 03:54 AM
Hi Theo23,
I hope your well.
The best way to synchronize your setup would be to use the trigger line of the frame grabber to trigger both the camera and your sensor. So at least the readings would be taken at the same time, despite the time the data taking different times to get back to the computer. This setup would rely on your sensor having a trigger input, does it?
If you would like to discuss this some more, could you tell me more about your sensor and setup.
Thanks for the post!
09-10-2008 03:39 AM
Hi Theo23,
I was just wondering how things were coming along with your application and I am just posting to check if everything went ok and whether the problem was resolved as I have not heard back from you. If you have any further questions on this issue, please post back.
09-12-2008 09:55 AM
09-15-2008 06:14 AM
Hi.
Thanks for your reply.
Well do you have any specific isssues that you need help with, or maybe re-thread them to get more users to see your post.
09-30-2008 09:25 AM
Hi
It's been a while since I posted my query but there is progress. I have merged together two different VIs that I found through your website and forum (after testing them and changing and adding staff). The two sensors I mentioned before (Microstrain G-Link and Inertia-Link) are now simultaneously storing data in a tdms file. The problem is that after about 4500-5000 samples for 20Hz frequency, the frequency starts to drop and finally becomes half. I used 'wait until next ms multiple' to synchronize the frequency. There are 9 channels of data, together with 2 timing channels in order to calculate the frequency, in the resulting tdms file. My first thought was problems with buffering the data but after several attempts I did not accomplish anything. Do you have any ideas. Any information would be useful
Thank you
10-01-2008 04:01 AM
Hi Theo23,
So your saying the loop iteration rate is slowing down after around 4500-5000 samples?
I feel it would be easier to debug this if you could post some code, preferably an example which generates this behavior your seeing in your project.
Kind Regards,
