Machine Vision
How does IMAQ SetImageSize modify images?
Hi
 I also tried using 768x 576 as specified in the documentation. The video image contains horizontal lines.
 I have attached the video image I get using IMAX.
Thank you
Murugan
Message 11 of 12
(992 Views)
Hi Murugan,
The images you attached indicate that this camera is not compatible with the CCIR format.  It works with RS-170, but this format can only acquire a 640x480 window.  I believe that the only option for getting a larger acquisition window will be to use a custom camera file designed for this camera.  Unfortunately, the PCI-1405 does not support nonstandard camera files.  The best alternative in this case would be to use a PCI-1410, which would allow you to use the camera file available on the NI Camera Advisor page, written specifically for your camera:
http://sine.ni.com/apps/utf8/nipc.product?pid=1982
Chris M.
Message 12 of 12
(969 Views)
