Hi Crispen,
Thanks for using our Discussion Forums. If you are using the Vision Development Module for image processing, we offer a function you may find useful. I am pasting the usage and description from the help file (for C programming). This might be along the lines of what you are looking for. You may also try manipulating an algorithm of sorts where you alter the region of interest of your image and appropriately scale the size of your display window correspondingly.
Regards
Dan
imaqZoomWindow
Usage
int = imaqZoomWindow(int windowNumber, int xZoom, int yZoom, Point center)
Purpose
Sets the current zoom factors for a given image window. The zoom factor indicates an increase or decrease in the magnification of an image. A positive number indicates a magnification by the amount specified. For example, a zoom factor of 3 indicates that the image is displayed at three times its actual size (3:1). A negative number indicates that the image is decreased in magnification by the specified amount. For example, a zoom factor of -5 indicates that the image is displayed at one-fifth its actual size (1:5).
Parameters
Name Type Description
windowNumber int The window number of the image window.
xZoom int The zoom factor for the x direction. Set xZoom to zero to maintain the current zoom factor for the x direction.
yZoom int The zoom factor for the y direction. Set yZoom to zero to maintain the current zoom factor for the y direction.
center Point The center point around which to zoom. Set this parameter to IMAQ_NO_POINT to maintain the current center point.
Return Value
int—On success, this function returns a non-zero value. On failure, this function returns 0. To get extended error information, call imaqGetLastError().
