10-28-2005 10:28 AM
10-28-2005 11:19 AM
In VB, no.
You could write a program in LabVIEW. You would need to figure out the distortions and correct for them, then merge the corrected images. You could use the NI calibration for the correction, but you wouldn't necessarily get the same scale on each corrected image.
Is there a significant benefit of merging the images? You would probably be better off calibrating each image separately, then locating several known reference points in each image - one point in each overlap area might work well. Once you figure out relative positions of the images, you could make measurements between images. For display, you could do an approximate merge of the original images without correcting the distortion. It wouldn't be perfect, but it would be fine for most applications.
Bruce
