06-16-2008 05:46 PM
06-16-2008 08:02 PM
The only way I can think of is to create a new image with the name you want, then copy the old image to that image. Another possibility is to create the image using the filename right before you load the image. I haven't ever tried to do this, though, so there may be an easier way. I can see this creating lots of images in memory if you keep loading different images.
Bruce
06-17-2008 12:32 AM
