Machine Vision
How can set a button to false when another button is released?
As I\m a beginner of LV, can someone please help me with this silly question? Is there any simple way?? Thanks!
for image acquisition, there are 2 buttons, "snap" and "grab".
"Snap" : switch until released, press once, it would autom. released when the process finishs.
"Grab" :  switch when pressed. press once will do the live mode, and push again will let it stop.
So if i click "grab" once, and click on "snap" without first stop the "grab", then after snap process finished i click again on the grab, then error comes, because not the "Grab" is still true..
i'm not sure if i have made myself clear enough,.,...but helpSmiley Mad
Chao
(3,673 Views)
can you please attach your vi also so that we can get a better understanding?
Sandeep
(3,656 Views)
Hello Schäfchen,
it would be really helpful if you could post you VI here (or at least a simplified). Otherwise it is quite hard to get the problem and, what is more important, to solve the problem.
I am looking forward to hear from you.
Johannes Gräper
Application Engineering
NI Germany
(3,633 Views)
Accepted by Schäfchen
thanks everybody, i have basically solved the problem using case structure, see the pic.
i think there must be better ideas, some simple way. I hope they would come up to me later.  Smiley Happy
PS: how can i set my question to "solved"?
(3,621 Views)
