11-26-2008 02:40 AM
Hi all,
I connected the Compact vision system with my computer by using cross cable.I gave 24v power supply to the CVS. I installed LV,RT,Vision development module and Imaq 1394 driver.But the CVS is not detecting in MAX. what should i do to get CVS in MAX?
11-26-2008 11:15 PM
Hello Kalanga,
1. I am sure you installed the IMAQ dx (newer version of IMAQ for 1394) drivers after installing the LV, LV RT, Vision Acquisition Software VDM and included support for your LV version during the installation.
Please have a look at the following link which explains the compatibility of different versions of IMAQdx drivers with LabVIEW.
NI-IMAQ and NI-IMAQdx Compatibility with Different LabVIEW Versions
http://digital.ni.com/public.nsf/allkb/6B55FF09D1FBD3108625719600650B7C?OpenDocument
2. Make sure that you have the same driver version installed on your system as is installed on the CVS.
The following KnowledgeBase Article will help you in troubleshooting the CVS:
CVS Troubleshooting KnowledgeBase Article
http://digital.ni.com/public.nsf/allkb/35D5C8DB4F1A66F5862571EA005D2FE3?OpenDocument#NotInMAX
Why does my CVS 145x Not Appear in MAX?
http://digital.ni.com/public.nsf/allkb/BF558F582BCC062386256DF6005D7BF4?OpenDocument
3. Try resetting the IP Address and rebooting the CVS in safe mode and then try detecting the CVS in your PC or on some other PC.
Karun
12-16-2008 01:13 AM
Hello Kalanga,
Has your issue regarding the CVS been resolved?
Thanks.
Karun
