07-12-2004 04:46 AM
07-12-2004 05:55 AM
07-12-2004 06:13 AM
05-06-2006 07:58 AM
05-08-2006 02:06 PM
05-10-2006 09:27 PM
05-10-2006 09:46 PM
Sorry forget to tell your my application in detail.
The project need to inspect on boad LEDs which consist of many Green LED + Orange LED + Red LED.
The software must able to detect the wrong color of LED, dim color of LED, and totally "OFF" of LED.
The method I use will be, Color pattern matching act as first pass to find similiar LED (If " pass " XY coordinate will be generated) , secondly use the XY coordinate + ROI to input to Light meter to extract RGB value and then following analysis will determine how bright or dim of LED.
But some problems arise, first too dim LED can not be find during color pattern matching therefore Light meter can not extract RGB value due to NO XY coordinate. Second the actual XY always not consistence after color pattern matching therefore the extracted RGB value from Light meter will vary......
Thank in advance...
05-12-2006 08:26 AM
05-16-2006 11:35 AM
