Machine Vision
How I can calibrate two camera web?
Hello
I'm doing a project vision. My project consists of an eye tracker, My project has two cameras. A camera for the scene and another camera for tracking ojo.He managed to continue the eye. When I detected pupil I've put a circle to indicate me where that pupil. Once you have the circle mapping camera in the scene, but the circle shown in the other camera is not calibrated, ie the position of the circle does not correspond to the position that I'm seeing with my eye. My question is how can I calibrate the two cameras, ie a camera pixel corresponds to one pixel in the other chamber.
Thanks a lot
regards
(5,544 Views)
you would probably need to calibrate your cameras as a stereo system. Then you could use fundamental matrix to map the pixel coordinates from one image to another. You would need to solve a homogeneous matrix system.
I have never tried to do this, but in theory it should work.
https://decibel.ni.com/content/blogs/kl3m3n
"Kudos: Users may give one another Kudos on the forums for posts that they found particularly helpful or insightful."
(5,535 Views)
Thinking about it, i am not sure that this will work... The fundamental matrix describes the epipolar geometry between two views, This would enable you to rectify the images, but you would still need to determine the correspondence.
If you rectify the images, you need to determine only the vertical pixel coordinate.
Let's wait if someone has any otheri ideas.
K
(5,530 Views)
it seems that I am not myself today. Smiley Frustrated
K
I meant to say that you need to determine the horizontal coordinate, not vertical.
K
(5,522 Views)
Thank you for your idea, keep waiting for more opinions.
regards
(5,520 Views)
Hello.
I've been looking for. I have a question as I can create a new item in matrix labview. Once you have these nine points as I know their cordendas. I attached an image of what I do.
regards
(5,458 Views)
